Keyin to open PDF file from within ProjectWise?
I have a client who is using a vba to open pdf files. I know there is a keyin "% \\engdat1\common2\MSV8i_support\Workspace\Clinet\Documentation\SheetSetup\Details.pdf" that will accomplish the same task. This keyin works outside the ProjectWise environment. If I use the same keyin to define a pdf file inside ProjectWise (using a managed workspace) but I use the file path URN, ProjectWise will switch to the location of the pdf file but the pdf file does not open.
Does anyone know of a keyin that will actually open the pdf file from within ProjectWise?
Microstation CONNECT 10.17.00.209
ORD CONNECT 2021 R1 10.10.1.3
Microstation v8i SS 10 08.11.09.919
Power InRoads v8i 08.11.09.615
ProjectWise 10.0.3.453
Parents Reply Children
