Microstation is suddenly displaying strange behavior with elements. This only started Today, after opening a file the elements are blurred and only appear clearly when the mouse is passed over them left/right or down/up but will not stay clear when moved back. What's happening?
5633.Test2.dgnHere's a sample file of what is happening (maybe it will work on another PC?). Note, I have had this file for a couple of years and never had this problem. All my old 2D files have developed this problem. However, if I create a new 2D seed file and copy and paste to it, there is no problem. Yesterday, I just updated my video driver to make sure I was up to date.
I tried your sample DGN, can not reproduce. I did find 2 dimension elements which seem to be corrupted (or something). Deleted them, file attached.
6064.Test2.dgn
It's possible that the update "broke" something?
Can you roll it back to see if the issue goes away?
MaryB
Thanks, that's interesting. I guess the file isn't corrupt because you don't have a problem. Also, this wasn't a single file problem but only my 2D files. That means it must be something on my PC. I hate to do this, but I'm going to reload Microstation. What do you think?
First I would install the previous video driver.
