Hi
Is someone updated what Autocad can handle nowdays regarding Microstation custom linestyles. We have custom linestyles in microstation that we hope would also work in Autocad, these custom linestyles are created with offset in microstation, is there a way to use the same kind of offset linestyles in autocad?Example offset custom linestyle in microstation:
Best regards
Tom
It would be great if you could share any new linestyle (LIN,SHX and RSC) if you manage to create awsome ACAD/MS linestyle
//Tom
The LIN file is an ascii file so it is easy (for them that can) to manipulate and change the information to that you want
