I am drawing lines that go -------T--------T------- if I draw from left to right . But if I draw them from right to left these lines are shown upside down.
I have recently come across a method that could change the drawing sequence of a polyline back to front but I can't find/remember it anymore. Can someone point me in the right direction?
f.mandoki said:Can someone point me in the right direction?
Is CHANGE DIRECTION what you need? See Change Curve Direction in MicroStation help.
CHANGE DIRECTION
Answer Verified By: f.mandoki
Thanks Jon, I'm not sure if that's what I came across but it works.
I actually found it in the Modify Curves toolbox that I added to my drawing tools a while ago.
