Hi
What is the confiuration variables to load ACAD lin file and ACAD shx files to connect? (even ACAD hatch)?
Best regards
Tom
As was suggested, any AutoCad line styles contained with .lin files need to be imported, either in the design file or a design library, via the Line Style Editor. The following information may be of assistance.
Line Style Editor Dialog
Line Styles And DWG Files
The suggestion to use the configuration variables, MS_FONTPATH or MS_DWGFONTPATH, is also a consideration and the following information may assist.
Fonts In MicroStation
DWG fonts are displaying incorrectly
SHX (AutoCAD Fonts)
Answer Verified By: Tom
