Hi all,
I created a parametric solid from a 2D profile, what i would like to achieve is to access the distance constraint "Dim" I added to the 2D profile to make the parametric solid. I want to create an item type expression to access it, is this possible at all?
I'm using Microstation Connect U16.
Best regards,
Cris
Hi Cris - You go the other way around. Create the item type first, then pick the item type from within the constraints dialog. To Use Variables from Item Types (bentley.com)
