When attaching a reference, is there a way to set the attachment method default to Coincident World?
I should have mentioned it's in V8i...
Yes it is possible. Configuration variable - MS_REF_DEFAULTSETTINGS
I've seen that referenced, but I don't know where it is to change. MS_REF_COINCIDENTWORLD=1
I was talking with another drafter here and he showed me where, but it does not work, not sure why...
Hi Travis,
I hope you followed the same steps to set coincident world as default in V8i:
Hope this helps!
