If you've heard of Axiom they create applications for MicroStation and since I started working at my job they've had Axiom's "File Fixer" for years and the renewal fee is pricey. I've never encountered having to use the application to fix a file but we renew it every year just incase we get a corrupted file. Do you guy's think it's worth renewing every year?
Eryk Aguilar said: I've never encountered having to use the application to fix a file but we renew it every year just incase we get a corrupted file.
Back in the 1990's this tool saved a lot of files. Even with knowledge in the EDG editor this tool saved countless hours.
With the move from V7 to V8 20 years ago file corruption became far less common. It is very rare to encounter a corrupted file now. You have to weigh the expense of the application vs how often you will have a corrupted file. In my view File Fixer is not worth the cost any more.
That being said, if you have their toolbox that includes Office Importer, Title Block Manager, etc. that you use a lot it's worth keeping.
Rod WingSenior Systems Analyst
I appreciate your feed back, thank you
FileFixer is mostly useless. I had much more luck with using generic structured storage tools(7-zip, SSview, Offvis) and fixing DGN files with these which was not possible using FileFixer or even contacting Bentley support. I still send the corrupted files just for fun to receive the standard reply to use backups(no such option to create them automatically).So if you have a corrupt file just drop me a message and I could often recover most of it. Also Bentley is working on replacement for Edg so soon could have a tool to audit DGN files.
DGN corruption stil happens but mostly it is lost model headers(bad error handling?) which is easy fix but somehow Microstation treats it as critical issue and doesn't even try to rebuild model index(key-in:model reindex) and Bentley support is no help either. Other issues are when part of DGN is overwritten with non-DGN contents. Not sure how it happens but seems a bad local network infrastructure. Mostly such issues are gone after upgrading local network to gigabit ethernet.
Oto said:FileFixer is mostly useless.
It was 2010-2015 when I had axiom tools with file fixer, it did scan and report on files before they became corrupt, and a few times we had corrupt files that mstn v8i could not open or xref anymore.. File fixer managed for me to get them open and repair most of the problems, so it was worth it back then.. Not so sure today in connect ed. but Bentley have been talking about an Edg replacement for years I hope we see it in our lifetime Otto, but will they charge extra for it?
Lorys
