10.17.02.61
I have a file that is being printed with Print Organizer and the fonts are not printing properly. Using the normal Plot Dialog, the fonts are correct. I have verified the plot driver is the same in both. There is a design script being used but it is applied in both and I verified it is the same design script in both. One other factor, this is being printed from a sheet model.
Is this a known issue with Print Organizer?
For now, I have our users .creating the pdf for this sheet outside Print Organizer
Thank you for bring this to our attention please raise a new Case and provide dataset / steps to reproduce for investigation, assuming not already done so.
Please also post Case # when done.
Ah, totally forgot about that setting. I just checked the print definition for the file and it does have a workspace set. I've instructed the user to clear that field and recreate the pdf. I am confident this will resolve the issue.
I never have that field set due to these types of issues in the past. I just forgot to check it. I'll verify that the issue is resolved once the user responds.
Microstation CONNECT 10.17.00.209
ORD CONNECT 2021 R1 10.10.1.3
Microstation v8i SS 10 08.11.09.919
Power InRoads v8i 08.11.09.615
ProjectWise 10.0.3.453
Clearing the workspace field does not resolve the issue. I've tried this with CONNECT U17.2 & Microstation 2023. Bentley suggested going back to CE 16 which did nit resolve the issue either. I'm leaning toward something in the Sheet Model since that is the only difference with the other files in the .pset. This is the only file that uses a sheet model.
I'm having the same issue!
Do any of the suggestions here apply?
MaryB
