Possible to import .e57 or .ply files in Connect?
It is always a good idea to mention the software and version you're using so we can provide the appropriate support for this software.
MicroStation Forum best practices
You should be able to attach an .e57 format file using the Point Cloud tools in MicroStation CONNECT Edition.
Point Clouds Dialog
As for the .ply format, you might need to use the Context Capture software to import or attach these type of files.
Add point clouds
Andrew Bell said:you might need to use the Context Capture software
Now this is known as iTwin Capture software.
Regards,Ron
