Hey there!
I have a survey dgn file with a level that includes trees (see image #1). I have referenced this survey file into another dgn file that has a closed shape of my tree removal limits (see image #2). I would like to count the number of trees within the tree removal area. Is there a feature/quick and easy way to count the number of elements in a closed shape?
I am working in Microstation Connect Edition (v10.16.2.251)
Thanks!
Hi Kundayi,
Try the following:
Regards,Ron
Answer Verified By: Kundayi Mugabe
You might like to consider using Reports in MicroStation CONNECT Edition to count the cells. Although the following Wiki article is from the Building forum it is still valid.
(CONNECT Edition - Is there any way to count all cells present in a drawing?
The following tool is from LA Solutions and Jon Summers and is quite good.
Count Cells with MicroStation VBA (la-solutions.co.uk)
This worked.Thank you!
