When I start MS 2023. I get this error pop up.
OS could not load C:\Program Files\Bentley\MicroStation 2023\MicroStation\mdlsys\required\pointcloudmdl.dll, error 193.MDL Loader: Unable to load library (DLL or MDL shared library) pointcloudmdllog4net:ERROR XmlHierarchyConfigurator: Cannot find Property [createpath] to set object on [log4net.Appender.RollingFileAppender]
When I try to use MS I get this .NET error
I have had a look in the folder and the dll exists. any ideas?
Ian
Hello Ian,
Would you be able to reproduce this error now?.
Siddharth
hi Siddharth
sure can and there are others
I get other .NET errors when i change the user preferences
I renamed the ma and dll. then tested. it addressed one issue. put the ma and dll back and did a reboot. seems to have fixed the issue
