[V8i SS10] SID image file - "The file type is not supported"
I need imagery from Tennessee for a project that has come my way.
I was able to download SID files (sid/aux/sdw/sid.aux.xml) for the area of interest, but I can't attach them. I can select them for attachment, but then I get an error "The file type is not supported - [13]"
I thought we could use SID images? Are there versions that aren't compatible with V8i-SS10? Am I missing a step?
Other people are waiting on me for this imagery, and I have no idea how to get it.
  • I don't have permissions to install apps to my computer, so I don't have anything to try converting the file.
    I'll try to see how it works in CONNECT later today or Wednesday. I'm not certain how exporting to another format might affect image quality or clarity, but it may be worth a shot.
    I'm currently using the Bing images, but those often "tile out" (switch from image to camera icon) when zoomed in, which makes them difficult to work with for the task I need.
    MaryB
    Power GeoPak 08.11.09.918
    Power InRoads 08.11.09.918
    OpenRoads Designer 2021 R2
  • Thanks for supplying a link to download your file but it keeps on failing to download. Not sure whether that is a problem on my side , or yours, but you might like to provide another method.
    Andrew Bell
    Technical Support
    Bentley Systems
  • Hi Mary, if you can open in connect then you  can use the  raster manager to convert to another  format that v8iss10 can handle. ITIFF or ECW can be  just as good resolution. BTW did any other  users at your work have the same problem?
    FYI you can install Irfanview to a usb thumb drive and run it  from usb .... its my favorite raster viewer as it gives a lot of info about  file and can also do batch conversions, very handy  when engineers have done lots  of iphone  site  photos...
    Lorys
    click link to PM me
  • Good to know!
    MaryB
