What is the road map after Microstation 2023?
When the version naming of Microstation changed from CONNECT to 2023, what does it means to the future? Or say, Microstation 2023 is a special memories version? In view of the long duration of infrastructure projects, it makes sense for the product line of Microstation last for 10 years (and become more stable). So i am confused with this new naming policy, but i found no useful information related to that in Wiki nor in Announcement forum.
  • When the version naming of Microstation changed from CONNECT to 2023, what does it means to the future?
    I think it does not mean anything, just naming:
    • DGN V8 format remains the same.
    • GUI remains the same.
    • PowerPlatform technology, at least what I see without SDK, is nearly the same (the same MSVC runtime, minor NET update from Framework 4.6.2 to 4.8)
    • QuickVision engine nearly the same (only minor update from 5.12.16 to 5.12.18, still based on DirectX 11)
    First personal impressions is it look a bit faster, so probably some internal optimizations and enhancements implemented.
    Hopefully they also simplify that - a simple OpenRoads Designer 2023 and then 2023.1, 2023.2 is all we need.
    I agree. The naming of civil products is confusing marketing chaos on drugs, nothing else. Impossible for normal user to understand what products are the same (minor updates based on the same civil schemas) and what product upgrade requires standards and DGN updates.
      Jan
  • Hi Jan,
    Nice run down on the changes. Looks like the 'Phase 2' iTwin engine or local iModels have not been included... yet?
    "Phase 2 of our journey involves improving our existing desktop products using the same iTwin engine. Users of our MicroStation and engineering design and analysis applications will next gain new features that can make their projects more efficient, more connected, and the results more valuable. We can do that by augmenting, not replacing, their existing tools, workflows, file formats, and deliverables. The iTwin engine will run on the same desktop ‘in process’ with the design applications, synchronizing a local iModel and connecting to cloud services when and as necessary.”
    Maybe this will be tied into the next version after ProjectWise 2023 rolls out?
    Curious to see how this would work.
Reply
  • Hi Jan,
