Nearmaps crashing Microstation Connect
We continue to have issue trying to attached Nearmaps , its been an ongoing issue in v8i and now connect
these are jpg files with a sister file,   not huge files,  10601 kb each,    sometimes it works as expected other times we attach more then one image it crashes microstation
and makes it corrupted ,  can someone please confirm these files are Connect Compatible. or something else is wrong
thanks
Karl Detrick
Cadd Manager
  • issue trying to attached Nearmaps ,
    can you detail the  work flow?
    I used to use loads  of  nearmap images in drawings without problems.
    Are you downloading the  images or  linked to wtf?
    Are you raster manager attaching the downloaded images to a holding xref file  with a defined CGS datum? then xref the  holding  file  to your drawings and  using a  CGS in the active file and allowing  mstn to reproject the  file if necessary ie  different  cgs in the xref and  active  file?
    Lorys
    click link to PM me
Reply
    Lorys
    click link to PM me
