Is there a way to rotate or mirror text and or dimension? If I try to do it, it stubbornly stays upside down.
NIco Leeuw said:Is there a way to rotate or mirror text and or dimension?
What is the exact version no. (e.g. v10.x.y.z) of MicroStation that you are using? Use key-in VERSION to see the version no. in the MicroStation Message Center, or Help→About MicroStation in the backstage.
VERSION
See this blog that shows you how to obtain MicroStation's version number.
If you're using an additional product (e.g. ProjectWise, OpenXxx) let us know about that too!
NIco Leeuw said: It stubbornly stays upside down
In a 3D tool such as MicroStation, 'upside down' could mean many things. Why not post a DGN example to illustrate your question?
10.17.01.62
This is what I mean with upside down.
Normally if I mirror something Microstation does it, but somehow there is some setting that prevents Microstation to actually mirror some texts and or dimensions.
