Hi all,
I am trying to use a EC Expression for a Reports Calculated Column Expression and can't seem to find a way to relate the expression to the model object being reported,
eg. i would like to use an expression like "this.GetElement().Name" to get the Name property of an element or a property using "this.GetElement().GetDisplayValue("xxx")" , however, i can't get this to work.
Is there some special syntax to get the report to select the current model object to retrieve values using Calculated Column Expressions?
Mark
Mark Shamoun said:I would like to use an expression like "this.GetElement().Name" to get the Name property of an element
A DGN element doesn't have a name. It does have a description. That is shown in our Area Report example...
Hi Jon, i posted a bad example as thats a property i use in ORD for Named elements. A better example for this would be this.GetElement().ElementDescription
Any comments from the Bentley team clarifying how these expressions work?
