Print to PDF: Geo Coordinates of cursor do not display from GeoPDF file
MicroStation, Update 16, Version 10.16.02.34, English
Please find attached ZIP file "BentleySupport.zip" containing some test data concerning the following problem description:
We are working with DGN file "test.dgn" and are using 2 different GCS elements, which can be found in the "GCS.zip" file:
  1. "Test_OK: Works  fine
  2. "Test_Not_OK": Does not work fine
With each of these GCS element we are creating a GeoPDF file as follows: File / Print / Print to PDF / Print to File ...
Using Printer Driver Configuration File = pdf.pltcfg with setting "Enable Georeferencing = On", (Base Properties / Driver Properties) . Result is:
  1. PDF file "test_OK.pdf": Geo coordinates of cursor are displayed in Acrobat Reader
  2. PDF file "test_Not_OK.pdf". Geo coordinates of cursor are NOT displayed in Acrobat Reader
We are using Adobe Acrobat Reader, Version 2023.003.20244
In order to use the delivered GCS elements you should do the following:
  1. Extract ZIP file "GCS.zip" to any directory "GCS_Dir", Example: $(MSDIR)Test\
  2. Set the following MicroStation config vars:
  • MS_GEOCOORDINATE_DATA = $(MSDIR)Test\
  • MS_GEOCOORDINATE_USERLIBRARIES = $(MS_GEOCOORDINATE_DATA)Test.dty[Test]
Question:
What is the reason we are getting GeoCoordinates displayed when using GCS "Test_OK" and not displayed when using GCS "Test_Not_OK" ???
Thanks a lot for any suggestion.
Martin Gitschel
Attached file: BentleySupport.zipBentleySupport.zip
