I'm not able to edit a microstation table outside projectwise. I used to work in a project set up in projectwise and I could easily 'annonate'-'place table' and edit them easily thought its a bit time consuming. However I'm not able to do that anymore as I'm currently working in another project that is set up in autodesk vault. I'm also not able to do the same outside vault in my local folder. Anyone encounter similar issue? Attaching a screenshot of how the table being imported from excel.
While working from PW, after importing a table, row names used to show up as numbered 1,2,3....etc & columns as A,B,C....etc.
The screenshot attached above, I'm not able to remove the fill colour as well.
Any idea how to fix this?
Insert option isn't working properly
Mohamed Abdul Rahman said:Insert option isn't working properly
5633.AreaAnnotator8.dgn
It works for me!
Not able to edit the table in the drawing you sent as well.
This error is showing up when I try to import a table into MS from an excel spreadsheet.
Have you come across this before?
Jon Summers Andrew Bell
