Change Background Icon
how to I make a toggle  icon so that I can change the background color between black and white?  I am always back and forth, depending what I'm working on.
Parents Reply
  • Hi Travis,
    One of the following key-ins should work for you.
    For Connect:
    calculator userPrefsP->flags.invertBackground=!userPrefsP->flags.invertBackground;update all
    For V8i:
    mdl keyin calculat calculator userPrefsP->extFlags.invertBackground=!userPrefsP->extFlags.invertBackground;update all
    These key-ins will invert the backgrounds of all open view windows simultaneously.
    It is a bit quicker than the other suggestion because it doesn't close and then open each window.
    It just does a simple update all.
    Ron
