I am relatively new to 3d modeling in Microstation.
Question
I see pop-up info is on for my object (e.g. cylinder, level = 1, etc.). Can this information in the pop-up be edited (i.e. include particular information such as color, size, etc.)?
If not, is there a way to create a pop-up that would allow the user to get that information as a pop-up or flyover?
update 17
10.17.02.61
you cannot change the information provided in the pop-up native in the application. You can get either the auto-popup info at your cursor when hovering over an element, or you can move your cursor over the element in question, hold Alt+Reset (right-click mouse) to get the "quick element info" dialog. Last option is to keep the Properties dialog open more often to access the same information.
https://docs.bentley.com/LiveContent/web/MicroStation%20Help-v24/en/GUID-BF692EE8-AB1C-438C-B82C-485547A82C05.html
Thank you for the information.
