Mstn Thumnails Size
Is there a setting that controls the size of the thumbnails? I understand that the thumbnail is generated from View 1. But even when I maximise the View, it doesn't seem to use all of the space available. See comparison with DWG.
Annoyingly, R*vit 's RFAs also produce better thumbnails OOTB.
I think I suspect Revit uses a Saved View to define the extents. This would allow the user to define an extents that better fits the square thumbnail space?
It would also allow the user to freeze the thumbnail as he will be using Ctrl-F quite often for other purposes.
Parents Reply Children
