3D DWG references changes in height when merging
Hello everyone,
When I try to merge DWG references in Microstation Connect "they jump" in the Z-axis. I seem to have this problem specifically with Microstation Connect and not Microstation V8. This seem to happen with all the DWG files I recieve from different stake holders.
After some digging, the correct height seem to appear after the merge process. How can I get all my references to show the correct height without having to merge them into my model? I have tested  changing the design file settings master unit between mm and meter without any luck.
  • if you export / convert your dwgs to dgn then xref and  merge does it still happen?
    I agree with you never happened to me in v8i.. But  I never used CE very much.
    Lorys
    click link to PM me
Reply
    Lorys
    click link to PM me
