Strange Results with Text Insert Field when using Item Type Definition
I am using MicroStation CONNECT version 10.16.03.11.
I have created a custom Item Type with a property definition (type = text) called Length2D. Under calculated properties, I am using the following expression.
System.Math.Round(System.Math.Sqrt(this.GetElement().Segments[0].DeltaX ^ 2  + this.GetElement().Segments[0].DeltaY ^ 2),1)
So far, so good. I then attach my item type to a 3D line. Under the element properties dialog, I find my item type, and it is reporting the correct value with the correct precision (i.e., X.X). Next, when I go to annotate my line using a standard text element, and I choose the Insert Field option, then select my 3D line, then I locate my item type property definition...the resulting value gets all mixed up and is incorrect. It seems to get rounded unnecessarily.
Please note again that my item type property definition is "text". It shouldn't do any rounding. Also, everything is correct under the element properties for my item type. The "bug" or issue appears to occur when the user tries to annotate the item type definition using a text field.
Does anyone have any ideas of a workaround to fix this issue? For example, are there any unpublished functions within the item type expression builder that fully commits a variable to strict text? I am grasping at straws here, but say like in VBA where you can use a function like STR to convert a number to a text. I am not sure this would solve my problem because again, everything is fine in the element properties dialog, but when I go to use this data and display the results graphically, then MicroStation "hiccups".
3D Imperial Design.dgn
  • Try System.String.Format. Check help
    System.String.Format ("{0:#.#}", System.Math.Round(System.Math.Sqrt(this.GetElement().Segments[0].DeltaX ^ 2  + this.GetElement().Segments[0].DeltaY ^ 2),1))
  • Hi Leonard. Thank you for the suggestion. I gave it a try, but unfortunately it produced the same incorrect result as I noted in my original post.
    As best I can tell, the calculations are being performed correctly in my item types. As I mentioned above, the correct values show up through the element properties dialog. However, there is a bug or issue when attempting to display the item type definitions via the place text \ insert field method. Rather than the software just going and "looking" or "grabbing" the values from the element properties window for the corresponding item type definition, it seems like the software is attempting to re-calculate all the item type definitions and then decides to add an extra layer of rounding to the results before applying it to the graphical piece of text.
    This is very frustrating. The correct value is there under the element properties window, but there is no easy way to display this information to the user, or an eventual client via a detail plan sheet, etc.
  • System.Math.Round(
    doesnt the  round part round the  answer, sorry I'm not  expert in the strings thing .. but hey wouldnt it  be better to use a data Field so you could define in the text as lenght  and set the number of decimal point and  have it associated to the element.. without using item types
    Lorys
    click link to PM me
  • Hi Lorys. I don't think Text Data Fields would work. Unless I am missing something, the data fields are sort of "dumb" objects that cannot be assigned to "read" or look up element properties. What I am chasing after is an "intelligent" text that can read information from my Item Type definitions (that have some basic math calculations performed within the expression builder of the item definition). If the user extends or shortens the line, then the corresponding text annotation value would update and report the new 2D length of the line element object (which will be a 3D line).
    Stated another way...I am trying to create a custom Dimension Element, but instead of using the restricted options that are pre-defined (e.g., length, angle, radius) as part of the Dimension Elements, I want to "pull/grab" the result of an Item Type Definition. In theory this should work with Text \ Insert Field process, but as I have discovered, there seems to be a "bug". If possible, it would be nice for someone from Bentley to acknowledge this, and then get it added to the pending issue resolution list.
  • ok were saying the same thing  now without using item types, bring up the text editor  type Length2D=
    but next use the  insert field ( this is a text data field not an Edit Data Field old school tech)  and  choose  length option property  and set the decimal places then it will ask to assign the text to which element. once completed if you  lengthen or shorten the element by its grab handles  you will get the text to auto update.. Yes the item types  or tag method will allow you to do reports  but what other things do you want to report , total lengths of all lines ? can be  done by select by attributes and level or colour  to create selection or via vba but IMHO select by is easier.
    look here example in ask inga ( they use area but  length for lines is available as well as radius for circles and arcs etc
     Text fields
    Lorys
    click link to PM me
