I was trying to copy some icons to make a custom tool bar with the active Level icon and Symbology preview tools. For some reason I can find these icons in the customize dialog box. I found the Abbribute tool under Application Tools hoping to copy those two buttons, but they are missing from the list. If I right clip and select open tool box, it has all 10 options, but in application tools customization dialog box, there are only 8 buttons. So I don’t know where else to find them in order to copy them to a custom tool bar. Any ideas?
Thank
Hi Abel
It is always a good idea to provide details of the MicroStation version number you're currently using as this can affect any answers provided to assist you.
MicroStation Forum best practices
CONNECT update 17
Microstation select series 10 ver 08.11.09.919
also have
CONNECT Ed Update 17
Version 10.17.02.61
Hi Abel,
Sorry for the late reply.
After further investigation this issue has been associated to BUG 1304827. We hope to solve this as soon as possible.
Thanks for bringing this to our attention.
At disposal,
Zeno
I upgraded to connect 2023 version and still the same problem, only have 8 buttons out of 10.
As mentioned above, BUG 1304827 has been associated to this issue.
If you are interested in speeding up the resolution process, you may consider raising a new service case that will be linked to this BUG. In this way, it will be possible to be kept up-to-date on the resolution process.
