Trim and extend tool needs to be updated
It’s time Bentley updates the trim and extend tool.
if you use autocad or inventor you can sweep over a line or arc and you can have it trim to a element or extend.
no snapping this element to the other element
  • Hi Kirk
    I'm not aware that the Trim Multiple tool requires snapping, just manual clicking, not that I use the tool at all but a quick browse of the help file suggest that's how it operates.
    The truth is, we already had the functionality (if I'm understanding your wish correctly), it was the Intellitrim Tool. I've never help back my animosity towards Bentley for removing the tool in Connect and replacing it with the Trim Multiple tool. Whoever made that decision is an absolute idiot in my book.
    You cannot tell me that this:
    Is better than this:
    When in the case of overlapped elements, tranditional method works better.
    Overlapping elements is probably not good practice (though it's not always avoidable) but selective use of level display, Display Sets or locking & unlocking of elements gets around any potential undesirable modification of nearby geometry (overlapping or not).
    On the other hand, scanning of elements for auto trimming/extending
    Who mentioned anything about scanning?
    may increase the instability of the operation of MicroStation.
    This sounds like absolute nonsense, Trimming or Extending has never caused instability of MicroStation, ever.
  • This still isn't as slick as Autocad Extend \ trim. acad you can just sweep across the elements
    Kirk
    I Wish Cadland was Reality
  • I don’t know the behaviour that you are referring to, presumably its the same interaction that the stream line tool provides. I’d happily stick with the existing behaviour over that, but that’s just a personal preference.
Reply Children
