Does anyone know where the explorer settings are stored? I assume in a user preference file, dgnlib, or xml. Just not sure where.
Thanks!
Steve,
Can you please provide the product that you are using, it's version number what setting in explorer are your particularly looking for?
U16, but am seeing it in newer versions as well. We noticed that the sheet index tool is not visible for us in explorer. I am trying to see what controls the explorer settings so i can do a bulk fix for everyone.
What do you mean by not visible, can you provide a screen shot of what you see?
I am not at my computer, but if you open Explorer Settings, there is an option to make the sheet index not visible in the explorer. Somehow that is set as not visible for multiple people. I am just trying to see where is that controlled at so I can fix it.
Out of the box they're saved to $(_USTN_PREFNAMEBASE).explorer-settings.xml in the same folder as user preference upf. Usually, C:\Users\<username>\AppData\Local\Bentley\<product>\prefs. I'd start there unless its location has been redefined by MS_EXPLORER_SETTINGS. If the same thing is happening to multiple users, then maybe MS_EXPLORERSETTINGSSEED is defined, and the seed file needs fixed. Hopefully that points you in the right direction.
Matt
