[MS 2023.00.01.44] complex shape not valid for remove vertex tool
Just wondering if it's WAD when the remove vertex tool doesn't work with complex shape in MS23.1? Sample file attached. Same file works fine in SS10.
Best regards,
Tuan Le
COMPLEX SHAPE_MS23.1.dgn
  • Hi Tuan,
    Can you specify the steps you took to create the complex shape in your .dgn file?
    I agree with Barry - it does seem that there is something extra contained in the complex shape (extraneous point) that could be causing the problem. If you simplify the geometry using the Create Complex Shape tool settings, then you can use the Delete Vertex on the element without issue.
    I am curious how the initial element was created. Maybe that can give us some clues as to how the issue came to be?
    Kind Regards,
    Jayson
Reply
  • Hi Tuan,
    Kind Regards,
    Jayson
