Can someone confirm the key in for 'model properties' because in the latest MS version (23.00.01.44) using 'model properties' doesn't work. It use to in previous versions as far as I can recall but not the latest.
We use this on a right mouse click to get to model properties quickly.
Can confirm that this key in works fine for me in your mentioned version.
Yvonne Lohse said:Can confirm that this key in works fine for me in your mentioned version.
OK. All I know is that it works in U17 but not in MS23, using the same configurations.
Is every user effected?In case only one single user is affected, please try to restore user settings to defaults: Restore MicroStation to Factory defaultsPay attention to backup your personal.ucf file before processing this since this will be removed too.its location could be found by key in:$ % explorer $(_USTN_HOMEPREFS)
I've restored defaults but the key in is still not working for model properties.
is the MODELMANAGER available in your MDL Applications dialog?If not please try to repair your MicroStation.
