I have added the Bentley Communities link to the Quick Access Toolbar but it doesn't work. That is, clicking it doesn't open the communities web page which is what I assume it is supposed to do.
I'm using the latest MS23.
Hi Stuart,
I tested this on latest version of MS2023, added Bentley Communities to my quick access toolbar and clicking on it takes me to MicroStation Community page. Perhaps a corrupt user preference is causing this issue in your machine. Try resetting user preference and try again. communities.bentley.com/.../how-to-reset-user-preferences-and-delete-microstation-s-temporary-files
Karan Sharma said:Perhaps a corrupt user preference is causing this issue in your machine. Try resetting user preference and try again.
Not that old chestnut again!! I did it last week for another issue with MS23 so don't expect it to be the problem. As it's not life or death I'll leave as is.
Please check if HELPLOAD MDL is loaded, if not load via key-in "mdl load helpload"
Then try key-in "help communities"
Standard Toolbox
Leonard,
That all works but that is not the problem. The button that doesn’t work is ‘Bentley Communities’.
The key you gave brings up ‘MicroStation Communities’, which works OK from the Quick Access toolbar.
What is the key-in for the 'Bentley Communities'. You can check this via the Customize Ribbon tool.
Is it "mdl silentload dynamicexamples;DynamicExamples Communities".
Try to key-in manually to see if it works.
