No file history when changing _USTN_HOMEPREFS
Dear Community,
I changed the Microstation CONNECT configuration on application level by setting _USTN_HOMEPREFS to a different value. The new .upf file is used, but unfortunately the file history is not stored in the .upf file any more. Any older entries from the pref seed file are displayed correctly. Anyone in this forum faced the same issue? Any suggestions how to fix this?
I use Microstation CONNECT Update 14.
Best Stefan
Steps to reproduce:
1) Add a cfg file on application level. Just add a file named nohistory.cfg under C:\Program Files\Bentley\MicroStation CONNECT Edition\MicroStation\config\appl
Content:
%if defined (_USTN_WORKSETNAME)
	_USTN_USERNAME          = ${_USTN_WORKSETNAME}
%endif
2) Call Microstation by explicitly use the following Command Line:
"C:\Program Files\Bentley\MicroStation CONNECT Edition\MicroStation\microstation.exe" -wkExample -wwMetrostation
