Merging files with Text Fields
 I'm merging files that have text fields in them, in order to create archive copies of issued drawings. Is there a way to convert the fields back into normal text without losing the information? Thanks,
 EF
Parents Reply
  • This thread was started many years ago about merging DGN files.  Since your question is specifically about MicroStation CONNECT and dropping text fields (whatever that means), you might consider starting a new thread having topic Drop Text Fields.  You should explain what you expect to happen when you 'drop a text field'.  Examples are always welcome to illustrate a question.
    Regards, Jon Summers
    LA Solutions
