How to get textelement rotation value in degree?
Hi all,
How can i get rotation value from textelement.It returns the value only in matrix3d.How can i get it in degrees like,,90,120,-45,-126...etc
  • VBA Forum
    Aravinthkumar:
    How can I get rotation value from TextElement. It returns the value only in Matrix3d. How can I get it in degrees?
    Post questions about MicroStation VBA to the VBA Forum.
    MicroStation is a 3D environment. A Matrix3d describes an element's orientation in three dimensions. A matrix is a better vehicle for carrying orientation than a simple angle because, in 3D, you need at least two rotations, and angular rotations are non-commutative. That is, a rotation about the Z-axis followed by a rotation about the Y-axis has a different result to a rotation about the Y-axis followed by a rotation about the Z-axis.
    There are ways to extract angular rotation from a Matrix3d. In general, angles are measure in radians in programming languages. Degrees are for human consumption — in this case, MicroStation VBA provides conversion methods. Lookup the Radians and Degrees methods in VBA Help.
    Regards, Jon Summers
    LA Solutions
    LA Solutions
Reply
  • VBA Forum
    Aravinthkumar:
    LA Solutions
    LA Solutions
