A lot of users want to give us input on what to do with the product. A lot of these ideas come to us as being really good from the start others require the user base to kick them around a bit (you can find a diamond in the rough a lot of times). Here is a suggestion on creating a post for your fellow peers to discuss and then how to submit it to Bentley to get it in the formal process.
Regarding TR's these are technical defects in the product. It is not recommended that you post things with "TR - (subject)", since it has not been determined if this is a true defect or not. If a post is determined to be a defect then if at all possible we will add the TR# to the original posts body, and if we catch the link while reviewing the fix we will try to post back that it has been addressed.
Regards, John Frampton Product Manager - MicroStation, PowerDraft Bentley Systems, Inc.
