I used the superscript aspect of the Word Processor dialog box this morning, and found that the size is way to small. If I copy / paste a superscript "2" from the Character Map it's fine, but the size of a 2 made into superscript with the superscript button on the WP dialog box is much too small. It's about a third of the size of a Character Map superscript 2. What is up with this?? Can the size of the superscript be changed? Would appreciate any tips. The Help menu in Microstation doesn't say very much at all.
Has this issue been addressed? The superscripts are still way too small - pretty much unreadable on the printed output when using our standard text size. I still have to leave a space and put in a separate text element. I most often use negative numbers ("-3"), so there is not option using insert symbol. BTW, the size of the superscripts looks good in the text editor window.
John
I agree, it's much too small - it either needs to be bigger by default or have a setting we can change to make it bigger.
For your information:
We have logged Change Request CR# 274461 for this functionality.
Hope this is of help.
Best regards,
Henk Ligtvoet
I have imported a DWG where the superscript part of the number is displayed as shown in the screenshot attached. (DGN left, editor right)
As you can see, the superscript part appears in a grey box and I can edit the number and it works and looks perfect in my drawing but what I can't seem to find out is how I can reproduce this from scratch.
Anybody know how this can be done?
