Tim,
Search the download section for a tool called CellTool. It should do what you want.
good luck, Ivo
Ivo Blaauw= = = = = = = = = = = = =Look what the CAD dragged in...
Have you tried the keyin : CONSTRUCT POINT DISTANCE ? That should get you the Construct Active Point ( or Cell ) @ Distance Along Element command. Hope this helps........
Jim
Try the Construct Array Tool and change the Method to Along Path. This should do the trick.
Stuart
