Is it possible?
Note already placed, can you add an additional leader that will be associated with the note (or cell actually) that will move when the note/cell is moved
Here is how I do it.
I place a note without text with the style I want. This will place a leader only. Then with the Association Lock ON, and then also checked ON in the Place Note Dialog Box, use Modify, and move the non arrow end to the spot on the text I want it to be. If you snap to the end of the previous leader it will not work, it must show you snapping to the text part. This magically connects them.
This is in XM btw, and I hope it makes sense.
--Kevin
Thanks for the neat tip Kevin. Is it possible to "unassociate" that leader after that?
You mean be able to delete the new leader? Yes, just deleteing it works, but no idea if you can unassociate, sorry.
For future reference:
"Tools→Manipulate→Drop→Drop Association" or Key-in: Drop Association
Thomas H. Stavik-KarlsenSenior Engineerhttp://www.Akersolutions.com
