Text underlining issue. How to increase the space btw text and line.
      I am using Roman font. When I select underline icon in the text dialog box, the line is too close to text. It's actually touching the text. But then I found a setting in change text attribute dialog box. If I check the underline box and select enable, this will leave a bit of space between the text and underline. But it is still not enough. Any way to increase that space? thanks.
Parents Reply Children
