Hi, I have just installed Bentley Redline XM on Windows 7 and it seams to be working fine exept that all RDL files I open are read only. They are not readonly in the file system and it makes no difference on what folders they are stored. I am running Redline as the Admin user and read only option is not on in the open dialog. If I create a new RDL file it is not readonly at first but if I close the progarm it and open the file again then it is readonly.
Do anyoune have any idea what is coursing this ?
regards
karl
Please be aware that Bentley Redline software is not compatible with Windows 7, and is not supported.
Bentley Redline has been replaced with Bentley Navigator.
Information on this can be found here:
www.bentley.com/.../ProjectWise+Navigator
