When you select text or any element and move it using the element selection tool, it would be helpful if there was a way to lock the movement to an orthagonal direction by holding down the ALT key. This is similar to holding down the CTRL key to create a copy. Perhaps you could even consider an option to hold down both CTRL+ALT to move/copy orthagonally,
Understand the above is possible using the Move/Copy commands with Accudraw, but this would useful for making quick non-precise adjustments.
Hi!
Just to give another option. Place the key-in "Lock Axis Toggle" (No " ") on a Function Key (F8 - same as Ortho lock in AC) (Workspace > Function Keys...) This would toggle the Axis Lock On/Off each time it is hit.
I Hope This Helps Someone Reading This! (Intergraph>PseudoStation>MicroStation user since 1980's)
