I am looking for discussion on what you would think about the ability to create Partial TextStyles and DimStyles. If this was mixed with Tasks and Element Templates a administrator could build cusom tasks with individual tools to apply the partial styles to the active settings. If these Tasks and Tools could remain persistent in a separate tool frame from tasks, this could be a user definable "Active Styles Settings" Dialog / Toolframe. The outline of the tasks could be something like:
Text Aspect (dgnlib)
I know a lot of this can already be accomplished using Tasks. I don't like the need to duplicate setting like text sizes and aspect ratios for each font. My current work flow is to create one TextStyle dgnlib as a template with all of the Text Sizes necessary for one Template / Font..Then I copy that dgnlib and change the aspect ratio. Then I copy both and chge the font:
Arial.dgnlib (Arial-L60, Arial-L80, Arial-L100, Arial-L120, Arial-L175, ...) Arial-Narrow.dgnlib (Arial-Narrow-L60, Arial-Narrow-L80, Arial-Narrow-L100, Arial-Narrow-L120, Arial-Narrow-L175, ...) Engineering.dgnlib (Engineering-L60, Engineering-L80, Engineering-L100, Engineering-L120, Engineering-L175, ...) Engineering-Narrow.dgnlib (Engineering-Narrow-L60, Engineering-Narrow-L80, Engineering-Narrow-L100, ...)
What do you think?
- Roy
Roy,
here's my setup I use since Annottaion Scale was presented in MS. I have only 2 dimension style set for Annotation Scale -- general and small one. I have 4 text styles set for Annotation Scale -- heading 1, heading 2, general text, small text - I'm using simple windows-delivered TTF fonts so they look same on every other computer
I set up 2 Templates - one for dimensions and notes, another one for text. I haven't yet fully tested the detailing tools
all geometry is in design model(s) and all the text, notes, dimensions ... are in sheets with Annotation Scale. I do not use any text in design model
this works fine for all my work
p.
/pt
Peter,
We use nearly all combinations outlined. This results in very unwieldy TextStyle & DimStyle selection boxes with all styles displayed. Choosing custom tasks defined for each makes this much more managable. It would be even more manageable if we could mix and match parts of the style definitions.
