Place Text Active Angle arrows bug?
Sorry,  I posted this in the general v8i forum.  I will post it here also.
 MS v8i SS1 (v08.11.07.180)
Has anyone else noticed that the lower arrow used to increment the active angle when using the Place Text tool is greyed out in SS1? The upper arrow doesn't work like it should either. For instance, if the active angle is set to 0^ before starting the Place Text tool, upon clicking the up arrow, the angle increments to 270^, then back to 0^, 90^, 180^, 270^, 0^, etc.
Has anyone filed a ST yet?
Josh Mauritz
