I was wondering if anyone knows of a way to extend the in-line leader of a note through (or in between) the two lines of text easily. Does this functionality exist within the dimension style? See image
TIA
Chuck
TRY THESE SETTINGS
Set in-line leader to a value
Set Left margin to a negative value
Set edit about to center
ORD - 2021 R1 10.10.1.3
ORD 2022 R1.1 - 10.11.3.2
ORD 2022 R3 - 10.12.2.4
ProjectWise - 10.0.3.453
Thanks for the reply, I'll check this out.
The suggested settings by mwlong do seem to work but only for limited circumstances. It only seems to work for 2 lines of text 3 lines makes the leader leg go through the note and with more the 2 line the underline leader usually goes under the first line of text. Also it seems as soon as the dimension style is saved and the leader is updated the text moves to the outside of the leader.
Mike LongstreetVermont Agency of TransportationCivil Engineering Technical SupportVTCAD Help
It's not perfect but works for the original question.
You will probably want to set up a separate style to avoid the text moving to a different location.
