V8i and Text Styles
Our existing Text Styles have a few issues with V8i.  The existing libraries come in fine and you can use them.  However, when you send the key-in, textstyle active (name), it’s not setting the text style active.  An example of our text style name is .07"  ENG-100  I have tried to create a new style and some funky stuff is happening.  It appears the quote is the problem.  Any help on this would be great appreciated.  Thanks,
Nick Johnson
MS 08.11.07.443
  • You've probably already have the answer for this, however for the benefit of others who stumble upon this question, here's some information.
    Your text syle must have come from MicroStation XM since that was the last version that allowed a quotation symbol ( " ) to appear in the middle of the text style name.  In the modern verison of MicroStation, a text style name can only contain a quotation mark at the end.  ie:  0.07"
    As you've discovered, the quotation mark is causing an issue when trying to activate the style via a keyin.  In this case, I would recommend that you rename your style to eliminate the " .
