Font degree symbol changes to fraction
I have a client font that is acting goofy. When I enter the degree symbol (Shift+6 carrot top) it looks fine. But if I do a text edit, it changes to a fraction. This only happens when the Text Editor Style is set to Dialog Box. If set to Word Processor it remains ok.
dgn and rsc attached.
I have not seen this issue with XM. Is there something to do within Microstation or should I try to have the client look into/fix this issue.
MS 8.11.07.180
Temp.zip
  • I'm seeing the same thing at my end.
    It appears that you can place a degree symbol without any issues.  It's just when you edit it that it becomes a fraction.  This is true for all fonts that support the degree symbol and not just those in your RSC.
    As a workaround, can you use the Word Processor to edit your text?
    UPDATE:  This was previously recognized and filed as TR #275625.
