dimension arc length
Someone else brought this up in the 2004 group but didn't get an answer.  There used to be a way to dimension an arc length.  You could cycle between degrees and length by pressing space.  Why this was changed, I don't know.  There is a setting in the dimension style to have it do length or angle but that seems stupid as you would need to setup a dimension style for each.  I found a key-in command that does exactly what I'm looking for but I haven't been able to find the button to do it.  DIMENSION ARC SIZE
Anyone have an answer?
Parents Reply Children
  • To switch to lengths or angle use alternatively the keyins: "dimstyleset angle units length" or "dimstyleset angle units angle". Would you need to switch that often? Do you think you need to have substyles or just to create buttons for that? I came up with element templates as I thought they may be helpful here as they help to define standards AND allow to use the Utilies>Standards Checker as elements "remember" which template they were created from. (They yet do not help for switching angle/length though). Gerd
  • Gerd
    I created buttons with the keyins. I find for my workflow to be the easiest way of switching between degrees and length.
    I don't stay in one mode of operation or task. I tend to bounce around between drawing to placing text dimensions back to drawing. So I should customize my task bars to all the tools I need are visible
    Kirk
    I Wish Cadland was Reality
  • I found this thread because I've got (once again) a customers question for a faster switch between angle and length. I agree with Kirk, that having each style doubled is definitively not an option. (Gerd, have you ever seen the number of dimension styles at BMW or Daimler ?)
    Wouldn't this be a good case for a CR ?
    The keyins are nice, but I know to many users, which wouldn't know how to implement this in a taskbar or even a function key (an customization by an external company is expensive).
  • I never thought I would ever have to correct Inga  but here are the correct keyins for v8i
    DIMSTYLESET ANGLE UNITS LENGTH;dimcreate angular arcsize
    DIMSTYLESET ANGLE UNITS  ANGLE;dimcreate angular arcsize
    Either use a macro to run each or a function key for each or alternatively make a homemade icon in your dgnlib file so every one can use it.
    I prefer a macro one called arcL and the other called arcA  could we make an alias or accudraw keyin to do this?
    Lorys
    click link to PM me
