CR# 93318
I would like to be able to change the TextStyle without changing attributes which may have already been overridden upon text placement.
Example:
Text to be modified was placed w/ TextStyle1 w/ overrides: JUSTIFICATION=CC
I want to apply TextStyle2 & all of the attributes of TextStyle2 with the exception of the Justification which I would like to be left with the override of JUSTIFICATION=CC; the same as it was when it was placed.
Roy,
I think you can use the "Match Text Style" tool to set the dialog box. Then use the "Change Text Style" tool. You would need to uncheck the "Text Style" box at the top of the dialog and then modify any other value that you want changed and uncheck anything you do not want to change. The text you are changing will no longer be associated to a text style.
Not sure if that helps or not but that is what I have had to do in the past.
Microstation CONNECT 10.17.00.209
ORD CONNECT 2021 R1 10.10.1.3
Microstation v8i SS 10 08.11.09.919
Power InRoads v8i 08.11.09.615
ProjectWise 10.0.3.453
Unknown said:I think you can use the "Match Text Style" tool to set the dialog box. Then use the "Change Text Style" tool.
When a Text Node has more than one TextStyle or there are overrides applied, this is of no use as currently the "Change Text Style" tool acts on the Text Node as a whole only.
Sorry, I missed that in the orignal post.
