Hello Everyone.I've just been doing an area schedule and required gross areas. Now to do this I was hoping that I could place a piece of text with a field (area selected) in it and select multiple shapes, that would give me a cumulative area of the shapes. However, fields only work, from what I know, on one object. Is there an intelligent way to make the field link to several objects and give a total area of the objects?I know of the cheating way to do this where one joins all the shapes via very small linkages that don't affect the overall area, but this is unclean and time consuming. There must be a better way!Ben
Unknown said:...(you cannot add or delete vertext unless you drop the grouped hole).
Since CE (2015) that you can insert and delete vertex from group holes (only deeper control for arc is still missing).
José
another quick way is to create a regular polygon like a square to enclose all the shapes ., measure this by element or you know already as you drew it, copy answer to excel or paper,
Then use the measure area tool by flood with locate internal shapes and remeasure this now gives the area less the internal shapes, the difference of this value and the earlier value is the total of the internal shapes..., I prefer selection sets measure area of selection , even by level names.. but this was a quick way when you have hundreds of little pieces or lots of shapes in a big design like cadastral property shapes...
Lorys
What I always do is to have a level on my dgnlib only for areas and put this elements on construction class. With named groups and a click I get pretty quickly with what I need. If needed I place text with field to these elements and they are always linked. But only element by element, not more than one. Regards
I prefer to use level names for area types for shapes then use the measure area on a selection by level name.. very quick smart way to work ... and it adds them all up...
But you must make sure you use the clean up tools first no overlaps, also check true islands and toroids or donut shapes, no duplicates, loop backs are bad too...then your file is available to use measure by element or level or colour.. I use to work in mapping and gis and this kind of thing was extremely important work flow as you will not get true area calculations... I like the text field method for presentation because its dynamic update but unfortunately as already discussed doesn't do aritmetic operations...
Unknown said:This has never really worked. Even in CE you cannot add the areas of multiple shapes. However, in CE you can run a report on the individual areas and exportthen to Excel and use Excel to total the areas.
Even in CE , whats needed is the ability to use a text field on a graphic group(ing) ie two or more shapes put into a graphic group then add the text field on group properties not element properties, this is not yet available but its on my wish list....
Unknown said: its on my wish list..
Put it on everybody's wish list by adding your idea to the Ideas Forum!
I've created a new idea for aggregate functions in reports and tables. Please vote!
Done!
