Is it possible to insert a text field with properties from a different dgn or model?
Basically what I would like to be able to do is have a note saying 'Refer to sheet XX' and the label 'XX' to be a text field for the sheet number property in a different sheet model. That when renumbering the sheets using Project Explorer, the sheet numbers will update and because all references to sheet numbers are fields, these will ultimately all update as well.
Any help is appreciated.
Jase
See "Link Sets"?
This is an old post but still relevant. I have a link set and sheet index in Microstation Connect. I can't seem to get the cross referencing of notes to work. How do I use either the sheet index or link set to do this?
