Some of the symboles are filled and shouldnt be.
i and K should not be filled when placed.
f has all kinds of trouble
The attached library has the following fonts... which one(s) are you having trouble with?
'CBTOSP' 85'CHAR_FAST_FONT' 127'char_fast_font1' 1'char_fast_font10' 10'char_fast_font2' 2'char_fast_font3' 3'char_fast_font4' 4'char_fast_font5' 5'char_fast_font6' 6'char_fast_font7' 7'char_fast_font8' 8'char_fast_font9' 9'FANCY' 138'font103' 103
CBTOSP
What specific version are you using (and comparing against)? I type 'iKf' for the CBTOSP font, and it appears the same in 8.5.2.70 and 08.11.07.443; neither 'i' nor 'K' are filled, and 'f' seems to display reasonably?
Did you place it with the Text Editor Style set to Dialog Box? Not Word Processor. I am using MicroStation V8i (select series 2) - Version 08.11.07.443
